Results 1 to 7 of 7
Thread: slight miss
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Default slight miss
    hey everyone. when my car is idling there is a slight miss. all new plugs, leads, and dizzy cap. what other options are there?
    VL RB30 Berlina
    Nov 2003
    is it running rich or lean? it could possibly be the timing
    Click the scales.....you know you want to!!!!
    vl berlina wagon 6cyl
    Jul 2005
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    VL RB30 Berlina
    Nov 2003
    check the power transistor(i think thats what it's called) on the dizzy(the single wire that plugs on the side)i had a prob with that a while ago and it sounds similar.....check the timing if you have the time...that can also make a big difference
    DenchY is offline project status = ongoing
    86' VL 323ci
    Mar 2005
    Newcastle
    check the gap on the sparkies i made mine all 1mm and it worked good
    other then that the timing
    megee83 Guest
    a bit of sh*t stuck in one of your injectors? mayb could run a cleaner through it or open up the throttle to try clear any blockage? (if there is one)... otherwise, timing or somethin, dunno... good luck, its those little bits an pieces that really piss me off when everything else is runnin well...
  1. VS supercharged slight miss
    By holden_fan69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2007, 10:29 PM
  2. a slight tapping sound
    By blake0182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2007, 09:45 PM
  3. Slight squek in the back of my car
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2007, 10:03 PM
  4. Slight Revs
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2005, 02:52 PM
  5. Slight Vibration
    By selvag in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-09-2005, 12:39 PM
