does any body know where the beeder valves are located on the head.how many what size spanner how tight to do em up?ect ect ect. plz help![]()
just sent an e-mail to your hotmail account
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
what size spanner? the one that fits of course!
the bleeder bolts can get stuck from corrosion if they havent been undone for a long time, causing them to shear off if forced
if they can be unscrewed, coat the threads with grease
with the bolts removed, place a garden hose in the radiator filler cap and surround with rag, and force water in until it runs from both boltholes, then replace the cap first, then the bolts
a cracked cyl head results if the bleeder bolts arent used properly
you need a 10 mm spanner/socket and there is one on the top radiator hose and the other on the top/front of the inlet manifold
Click the scales.....you know you want to!!!!
i wouldn't risk the bolts. just undo the top hose on the inlet manifold. get a big coke bottle so when pouring water in the radiator the end of the bottle is higher than the head. once water starts coming out the hose whack it back on.
found one that fits but i think its a lefthanded one
