i need a new gear box soon (well i want one anyway i dont really need one YET) but will the s15 6 speed fit. or any nissan gear box? maybe stupid question but hay its not the worst ive seen
any gear box should fit if u get the bell houising. but as for the size it could b to big for the room allowd and a custom mount might need to be made
my opinion a 5spd is ample enuf for a vl
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
6 speed would be nice... you should be able to adapt whatever you want to fit, space will be an issue because its pretty squeezy in there already. so if the box your looking to put in is larger, youll have to modify the tunnel there. i know when my old man had to modify his EH ($45k+ spent, 16yr build time... thats dedication!) to fit an ecotech six an box, it involved cuttin through a chassis strength section, and then as a result needed engineering certification. dont think have the same issue with the VL though... easier an cheaper to jus rebuild the 5spd an whack that back in there, unless you dead keen on the six.
If you mainly doin city drivin though youll end up with one leg bigger then the other from pushin the clutch so bloody much![]()
i'm pretty sure that the patterns are the same but if not then you can more than likely but an adapter plate....the big issue will be the cross member and as megee83 said, the space.....find out the dimensions of both and compare them....that should at least give you a basic idea of what will have to be done in regards to the room side of it
Click the scales.....you know you want to!!!!
6 spd VL = Blown Engine
6 spd VL with engine work = 1 hell of a ride!!!
I wonder what those scales on the top right side of my posts do...
