How do you disconnect the cable thing from the back of the speedometer?
PULL....... think theres a leg that it clips on2 just lift it up and pul like hell, look though ur window to get a good view how its connected if ur still unsure
helps if u can bend ur wrist in wierd ways![]()
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Yeah i looked through my window to see how it was connected and looked at the other cluster, looks like that whole big metal thing stays connected to that wire thing, just didn't want to break it or ill b up shit creek...as for bending my wrist in weird ways i can't see that happening as i have re-fractured it; i believe (it hurts when i move it; getting it checked out). I'll give it a go though, if i break it can i blame youOriginally Posted by VL Berlina 5speed
Is it easier to put it back on?
Mate its easy eh! Theres a white plastic plug clip thing with a lever you have to press inward toward the cable itself and it just slips off by pulling backward. Then it slides straight back on!!
yere little white plug like on radios in cars sorta
http://img82.imageshack.us/img82/655/001pattis0us.gif
.....\...\...\...... _.·´
Why u wanna remove? the how to's have already been covered but make sure u put the speedometer plug back on.. properly n also the plug at the top of the cluster neeeds to be pushed in both sides (as well as the clip in the middle, coz that controls blinkers etc and if its the original cluster, chances are it wont sit properly.. then u'l b drivin with no speedo n no blinkers..
might be fun at first but then...![]()
I wonder what those scales on the top right side of my posts do...
All good the new cluster is in and working it was the white clip thing that got me buggered...it was on the underside and could only see the clip thing when the old cluster was lifted...What sorta reading comes on with the oil pressure; should it be at 0 if no oil pressure sensor; or at 5?
Everything seems to be working on it bextor...except maybe the speedo, didn't test it, i got the tens digit stuck mid point when winding the kms up (2109(78)7), so i just stuck my old speedo in.
now ur truly honest u winded ur clock to what the factory 1 said, most ppl would just left it to gain some money at sale. now i would buy a car of u coz i know u wouldnt replace the dash with fake ksOriginally Posted by Jules86
my gauge for the oil reads 5 constantly when running and 0 when motor off (i cant figger that out LOL)
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
Does that bcause you need an oil pressure sender. Mine does it also.
DaZ
Project: Shifty1 commences Feb 2007
The_Monk says:
im a leech
Its a sweet mod aye, after a while the novelty of the tacho dash wears off a little and it becomes the norm. My volt meter is still stuffed but everything else is still working and oil pressure guage is like an on and off switch until you get a variable oil pressure sender fitted to your block (the wire and plug are under the intake manifold wrapped around something in all VL's)
