Results 1 to 3 of 3
Thread: Air flow metre
    Dead Head Guest
    Default Air flow metre
    can anyone fill me in on away to adlust afm fairly close
    EF Almost Turbo
    Jun 2005
    OK Simple
    The AFM sensor is on the air intake pipe. Unplug it and attach a voltmeter/multimeter to the first/last pin. It should read 382 ohms. If it doesn't, the circle to the left contains a screw that you can adjust to make it read 382.
    (PS, Yes I did this is on the VL and it improved economy)
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    vl berlina wagon 6cyl
    Jul 2005
    there must be no leaks in the rubber sections of the air intake system or the AFM cant work properly as air is being sucked in upstream of it
    with a faulty AFM, my VL would only just idle but couldnt be revved up any more
    is there any sort of a 'get you home' fix if the AFM suddenly stops working?
  1. maf and airflow metre
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2007, 01:16 AM
  2. vn trip metre
    By blue vn in forum Electrical Wiring / Questions
    Last Post: 31-07-2006, 05:51 PM
  3. vl turbo - consistant air flow metre blowing????
    By omnivl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-05-2006, 01:05 PM
  4. afm ( air flow metre)
    By markandsam in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-12-2005, 11:52 AM
  5. what to with air flow
    By HSVGTSTOY in forum V8 Development and Modification
    Last Post: 08-03-2005, 10:10 PM
