Results 1 to 12 of 12
Thread: ECU Help!
    VL
    Jul 2005
    SA, Mount Gambier
    Default ECU Help!
    I just did an ecu test on my mates vl, come up with codes...
    13 - Temp sensor?
    23 - Throttle sensor?
    24 - Neautrul switch
    31 - system pass?
    The vl runs fine, should he do somthing bout these codes?
    VT SS S2 A4
    Aug 2005
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    megee83 Guest
    11 crank angle
    12 Air flow
    13 Coolant temp
    14 Speed sensor
    21 Ignition signal circuit
    23 Throttle switch circuit
    24 Neutral Switch circuit (auto's only)
    31 Air-con circuit
    32 Starter signal circuit
    34 Detonation sensor circuit (turbo's only)
    44 Satisfactory operation (air-con models only)
    pulled this off another thread, according to that there nothin you need to worry about except the temp sensor for your coolant there. i dont think that should spit out? give it a check, mayb change it out/flush radiator an the rest, if it runs a little hot. i know the rest of the codes are normal if you dont follow the procedure exactly so nothin to worry bout.
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    mine come up with 12 and 31..
    the air flow (12) can that get fixed by adjusting the afm to the .382 ohms?
    and also my aircon circuit (31) is that coz its completely outa gas (from when i changed engine)? or is it the actual circuit..?
    I wonder what those scales on the top right side of my posts do...
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by markiuliano
    the air con comes up normally. you have a proceedure to follow that should cancel the code. then check again. there's another thread here where i wrote the proceedure down.
    Jul 2005
    ok kool.. wot about air flow?
    VL
    Jul 2005
    SA, Mount Gambier
    Bax
    Nothing
    Jan 2004
    QLD
    About how to cancel them, get in and drive over 10km/h aircon on and off, go through your gears, etc etc. Just do everything and anything.
    megee83 Guest
    to cancel 14 - you got to drive over 10kmph
    cancel 23 - push the accelerator down
    cancel 24 - put it from neutral into any gear
    cancel 31 (if a/c) - turn it on an off.
    31 (non a/c) or 44 (a/c) will also come out if everythins good. if the car runs fine id jus leave em, doesnt matter, if there was some sort of prob an i wanted to check the comp id go through an cancel them all.
    back to the first question but, are you sure you got 13 an not 14? cos you should have got 14 to start with... mayb a miscount?
    also you will get 32 if you run the test without startin the car up.
    VL
    Jul 2005
    SA, Mount Gambier
    Im not 100% sure on what i got, i couldnt really concentrate on the flashes properly that night lol, but i will probs have another go. coz of the error 23 he went and got a TPS lol but its all good.
