Just wondering if anyone can lend a hand my CAS carked it and I have just finnished installing a new one, only problem is that I had to remove the complete dizzy and now I dont remember at what spot it was, any suggestions on how to fix this problem? Tried starting but wont start must have reinstalled it incorreclty.
have u tryd putting it on and starting it, and if it dosnt then turn it a bit more and so on till it starts the use a timing gun to adjust it to correct timing.
i reckon ive got a pic of the dizzy out of my car ill try finding it 4 u so u can see wat way its mounted and whats the rotation on it.
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
dose this help?
look at the gap where the bolt is and the braket is, sure if u adjust it 2 that itll work, mine runs fine but still should check the timing to make sur eits good coz every motor is differant
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
