Results 1 to 4 of 4
Thread: Removing VL Fuel Tank
    VE Lumina
    Mar 2004
    Default Removing VL Fuel Tank
    Hi, I have recently installed a 12" pioneer sub in the boot. It was making the boot lid rattle like crazy, so i sikaflexed the frame of the lid to the outer "skin". That got rid of the boot lid vibrations but now the boot floor is vibrating against the fuel tank.
    How hard is it to remove the fuel tank and put a rubber/foam sheet ontop and put the tank back on??? What is involved in this???
    Thanks
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    not hard to remove tank. I did it from my mates wreck. It has "belts" strapped across it. Undo bolts to free straps & you might not even need to get fuel filler neck out cus you want to put it straight back in? Try working around it?
    D.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    VE Lumina
    Mar 2004
    Ok cool...Ive heard that if you remove your fuel tank that you will probly have to replace the fuel line because they crack when you remove them? Is this true, and would i have to remove them if you reckon im only going to need to lower it a bit???
    Also what and where is the secondary fuel pump and what do i need to be careful about.
    Thanks guys(and girls)
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2012, 05:14 PM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2010, 04:29 PM
  3. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-07-2010, 01:15 PM
  4. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  5. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-05-2007, 09:01 AM
