Results 1 to 14 of 14
Thread: Stalling
    VLtuff Guest
    Default Stalling
    My car seems to stall at times, usually while idling at the lights. I wait about 1 minute and then its starts again fine, and drives normal. Any suggestions? replaced leads, spark plugs are fine
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    Auto or Manual?
    Reset the computer n it SHOULD fix that problem...
    Not that that happened to me..
    (Thats if your cars in good running order..)
    I wonder what those scales on the top right side of my posts do...
    VLtuff Guest
    Jul 2005
    Did u reset the computer?
    Jul 2005
    Try resetting the computer.. that should fix.. (remove battery and disconnect the computer and air flow metre overnight is the proper way to reset it.. according to mechs)
    If still doesnt fix, run the computer on diagnostic mode.. it could be the air flow needs adjusting or maybe your afm needs replacing..
    But first just try resettin the computer.
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    from my experience of stalling i'd put it down to either faulty air flow meter OR your crank angle sensor is on its way out. my car used to stall while i was driving it. there was also some rusty terminals making bad connections, might be somthing as simple as that
    VLtuff Guest
    ok, i might try resetting the computer. Ill check the air flow meter, it should read 382 ohms yeah?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    yep 382ohms
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Jul 2005
    how'd ya go mate?
    VLtuff Guest
    nah, problems still there. im gonna try a new dizzy cap and afm tommorow.
    Jul 2005
    most probably afm.. maybe borrow a mates first before buying a new one jus to see if it fixes the problem..
    DenchY is offline project status = ongoing
    86' VL 323ci
    Mar 2005
    Newcastle
    mine stalls when it gets hot.. the fuel gets to hot and dont go boom..
    does it only happen on a hot day?
    ill be puttin some airflow thing up to my fuel canister bet it fixes my problem!
    JBVL is offline Retired Dirtbiker
    VL 1987
    Dec 2005
    Australia, QLD
    erm i wouldnt recommend betting your balls on that....
    Does this mean you'll pour petrol all over yourself and allow me to throw my ciggarette at you on a hot day?
    megee83 Guest
    Quote Originally Posted by DenchY
    actually buddy, if you get fuel hot enuf, it will go boom all by itself...
    this ones straight out of the book mate, saw it yesterday when i was testing my computer:
    If the vehicle runs normally until it is hot and then suffers a sudden ignition failure which then cures itself after the engine cools down, the most likely cause is a faulty crank angle sensor.
    However other causes could be a faulty ignition coil and to a lesser extent a faulty power transitor.
    Hope that helps, like i said, straight out o the book...
  1. VS almost stalling
    By Col74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 01:07 PM
  2. Stalling VN
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2006, 11:03 AM
  3. Car stalling
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2006, 01:25 PM
  4. My VN keeps on stalling! Help!
    By VNDAVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2005, 10:38 AM
  5. Need help with stalling vs
    By Sandman240588 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2005, 11:28 AM
