Results 1 to 5 of 5
Thread: 70ml Ford Throttle Body onto TURBO
    VR Acclaim S2
    Feb 2005
    viewbank
    Default 70ml Ford Throttle Body onto TURBO
    Hey every1
    Wanna know if there is any mods needed to relace the standard throttle body on a vl turbo to a 70ml Ford XE XF throttle Body???
    Any help would be appreciated
    VR Acclaim S2
    Feb 2005
    viewbank
    VXII Exec
    Jan 2006
    NTH Suburbs Melbourne
    Why not get an aftermaket ones as they're bigger than the ones ford can supply.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Because the XF t/b is generally a fairly easy swap anyway. You should look into getting a custom plenum, some already come with the XF tb and they are getting alot cheaper, you will see much more results with the addition of the added capacity aswell.
    And I'll answer this post soon, just typing it quickly as I have to go out.
    VL RB30 Berlina
    Nov 2003
    if you put a xf throttle body on you have to bridge the coolant lines.....that's all you have to do from what i have heard......
    Click the scales.....you know you want to!!!!
  1. Re throttle body v8
    By hsv26c in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-10-2007, 06:39 AM
  2. Throttle Body 4 L67
    By VS CALAIS in forum V6 Development And Modification
    Last Post: 30-06-2006, 10:13 PM
  3. Ford Territory Turbo!
    By Jamie_87 in forum The Pub
    Last Post: 12-05-2006, 08:57 PM
  4. Holden Gemini into Ford Escort Body
    By VB Owner in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-10-2005, 05:37 PM
  5. turbo throttle body...
    By superal in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-07-2005, 09:49 PM
