+ Reply to Thread
Results 1 to 12 of 12
Thread: turbo or manual???
    thestash_16 Guest
    Default turbo or manual???
    hey all, i was talking with my mates and they suggested about getting my auto trans and ditching it for a manual transmission. How much would this cost and what would i have to change on my car?? on the alternative side, they suggested installing a turbo. what do u guys reckon, and what would be cheaper and better??
    cheers!!
    Boonz's Avatar
    Boonz is offline the holden mechanic Boonz Maloo Boonz Maloo
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    bangers's Avatar
    bangers is offline <<<There's a good present bangers has disabled reputation
    EL FALCON XR6
    Aug 2005
    NSW
    depends how much power you want. and how much you're willing to spend. puting a manual in will be HEAPS cheaper and easier. you will get a power gain at the rear wheels. turbo is expensive and lots of parts and work are needed but you'll get HEAPS more power from the engine. And looking at your age i wouldn't go near a turbo. depending where you're from it could be illegal. put the manual in for now if you have to have more power and some engine mods and do the turbo when you're a little older and wiser.
    VL RB30 Berlina
    Nov 2003
    there's a post in the "everything to know about vl's" with the conversion in it....manual makesdriving more fun than auto.....also it depends which block you have to convert it to turbo...if it series one then you have to drill and tap holes for the turbo feed/drain.....i personally went manual.....the only complaint i have against it is when you are in traffic.....the rest of the time it better than auto cause you have a bit more control of the car!!
    Click the scales.....you know you want to!!!!
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i agree with ^^^^^^^. if you do go for the manual don't worry about the crap everyone says about changing the ECU and loom. you don't need too. a VL manual will run on a auto ECU but an auto won't run on a manual ECU. Just leave the transmission plug unhooked from the ecu. Then close the neutral switch circuit so the car will start in gear and neutral. then wire up reverse switch to lights.
    VT SS S2 A4
    Aug 2005
    Bax
    Bax is offline Projecting Bax Monaro Bax Monaro
    Nothing
    Jan 2004
    QLD
    Turbo would kill your auto and you'd have to change it anyway.
    Manual it is.
    VT SS S2 A4
    Aug 2005
    Thats true, you would need to get a decent trans cooler if you went for the turbo option.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by rb26dett
    bloody oath. then you'd need a stage 2 or 3 shift kit to hold it together and whatever else to stregthen it. thats is of course if you want a half decent psi off the turbo.
    Jan 2006
    If you're gonna keep it N/A, Manual by a easy margin, if going Turbo get a Manual anyway.
    megee83 Guest
    manual manual manual manual manual manual manual manual manual manual manual... you can pick up the box for a few hundred bucks, an do the work yourself. manual manual manual manual manual manual manual manual manual manual...
    yeah, i reckon go the manual...
    nauta_boiVL Guest
    manual man!!! so much more fun, betta for smoken them up too ahaha... do what u want but i preffer manual any day
+ Reply to Thread
  1. VL Calais Turbo, manual
    By sean3111 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-12-2008, 04:59 PM
  2. Researching Auto/Manual for Turbo
    By Avi8or in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2007, 07:37 PM
  3. Whats it worth? Turbo VN V6 Manual
    By jonno_12 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2006, 01:49 AM
  4. WANTED: ECU for VL 5spd manual TURBO
    By lovemyvc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2005, 05:04 PM
