ahhhh i bought a vl and i have taken out both front and back windows and theres a lot of mainly surface rust around the window edges... would sand blasting be the option?? or is there another way to get it out? thanks
sand blasting will be filthy
if it's surface rust, grind it off, it its deeper, cut it out with a thin cutting disc, and weld a new piece in.
just have a mate stand by with a wet rag to put on your work when it warms up to prevent warping.
ahh k, sweet thanks mate... yeh its pretty much just surface rust.. a metal brush might even do the job.. yeh with sand blasting alot of sand will get thru the car ide imagine, very messy
the area where the glass is glued to seems to have been left as bare metal and rust is very common
yeah they didnt cote it, i got the metal under the rear window cut out and replaced in my vl
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
ahh k cheers, its mainly just surface rust so i dont think i will get that metal replaced.. if i find a slaight rust hole i might just mig weld it up then grind back
How do you prevent surface rust from coming back??? i got rid of the surface rust in my boot but its back...Also i have a hole in my tyre well...i was just wondering if i cut it out and put some rust prevention paint on it; can i use fibreglass repair sh*t to fill over the hole. Cuz i'm not too sure about welding in some more metal.
To stop rust coming back, treat it with fish oil, then paint over it properly with some rust kill primer and then your normal paint.
