hey guys,
just wondering if anyone knew how to change over the front door locks.
is it a easy or hard process and if anyone knows the process if they could shed some light on it.
getting my locks in the next couple of days.
thanks guys and girls
remove door trim,
remove plastic dust cover,
look in behind door lock you should see 1 or maybe 2 little bolts,remove then
remove door lock pin connection
slide metel clip out of the way
push door lock out, and install is the same as remove but reverse
Real cars don't power the front wheels, they lift them
