Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: supercharged vl's
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Default supercharged vl's
    has anyone seen or heard of a VL being supercharged instead of slaping on a turbo because i was thinking today about it and wondered what it would go like??
    VT SS S2 A4
    Aug 2005
    Boonz's Avatar
    Jul 2005
    pro1438 Guest
    DVS87 Guest
    hey bro, we supercharged a mates one. left it auto and got a bolt on supercharger with a wastegate and skyline gtr intercooler (off a mates gtr, was lying around) and ran 12psi. ran a low 13sec quarter. reckon bigger aftermarket fuel pump intercooler some head work and larger injectors we could get it into the 12 sec quarters. only hassles we had were gettin all the plumbing right although we did it oursleves and the battery had to be relocated to the boot
    Boonz's Avatar
    Jul 2005
    do you think it went better than a turbo? it would definately have better bottom end but whats the biggest advantage u rekon???
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    turbo is a heaps cheaper option, and wouldnt you need an engineers cert for the supercharger because it was not an option?
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    advantages are a couple in favour of supercharger. it's pretty much bolt on. with turbo you have to work out your plumbing and turbo size to reduce spool time. another advantage is you have the extra power from the moment you touch the accelerator. although like a turbo there is only so far you can go without modifying and strengthening the internals of the engine. IMO i like the supercharger for the power from start but after working around turbo's i like that sudden punch in the back when it kicks in. I suppose it comes down to your wallet and whats available to you.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Searching is a good option here. Been covered to very fine details. Low 13 second quarters.. 12 psi. What charger was this? I can't see the SC14 being capable of that.
    DVS87 Guest
    not sure what charger it is, find out for u though. engineers certificate is a peice of cake to get and compared to turbos im not too sure. i like it but then the wastegate allows u to have the boost when u want it so its not straight up tourque. i guess it depends how u set it up and how much tiume u have to play with it
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    i saw a s/c kit a while ago on the net. Said it gave the standard VL motor 30rwkw, bringing the standard kW up to roughly 110rwkw, which is a little bit faster than a VS Ecotec ... which still isnt all that quick
    EF Almost Turbo
    Jun 2005
    Anyone know the cost of a SC14?
    Thanks
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    Bax
    Nothing
    Jan 2004
    QLD
    Steve-0 Guest
    what quarters would the SC14 be capable of? and being such a small sc stock internals would last a while wouldnt they?
  15. #15
    VS Commodore Omega
    Apr 2005
    Probably obvious but remember people - If you're making it go faster, do the brakes so it can stop faster as well.. and probably the diff lol
  16. #16
    Sep 2005
    vic
    yeah, people dont seem to factor in those things, you will need better breaks, the trans wont be able to cope, especially the auto. the diff will shit itself.
    my web site
  17. #17
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    plus you'll have to change your belt setup. different belt hubs to accomodate your s/c drive belt. maybe even put a serpentine belt on.
  18. #18
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    The engineers certificate is a must if you are doing a power upgrade like a turbo or S/C even though the VL range had turbo as an option you will still need an engineers cert to turbocharge an NA. You apparently need one if you fit bigger wheels even (technically) but no-one seems to follow this rule and the cops don't usually enforce them unless you are on your P's and they feel like it LOL.
    ========My Statesman 20's Mafless and 3.9's========
  19. #19
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Oh and also this CRS kit will not bolt on with the P/S and A/C in the factory locations. which makes life a little harder but not impossible. I reckon with a fuel upgrade,exhaust, CAI and filter and an aftermarket ECU you could squeeze 50rwkw from the CRS kit.
  20. #20
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by ucwepn
    Would be interesting to see how it goes, as I have never seen a supercharged VL in the flesh.
  21. #21
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    there was a supercharged vl in street commodores magazine a fair while ago had the plates ovl087 i think came from goulburn...was bright blue but it ran a good blower.......
    ther crs kits are shithouse they only bring it up to a stock vlt power output..... and thats pushing the lil chargers to the limit unless u got a few grand for a good blower and engine uprgrades turbo is much beter option...
    the crs kits are $1500 aswell.....stock vlt setups run for lower then that
  22. #22
    VT SS S2 A4
    Aug 2005
  23. #23
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    ive been thinking about this and i would love to do this in time to come but i was thinking about the P/S and AC pumps being moved, i could live with no AC but the P/S wherer would be the best possition to move it to and how much would that most likly cost,
    http://www.rodshop.com.au/superchargerb30.htm
    there is the details on the castlemain kit
    and one more thing,
    would there be any way of getting extractors to fit in behind that pipe or would a new intake pipe be needed or is that pipe spec tuned in length and size?
    front on pic
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  24. #24
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
    mate of mine did this 2 his r31... gave it like 117 rwkw and it was a head case having 2 make up braket's etc and no sean the extractors wont fit around unless u modify them.. mate also had that problem, how his car is turbo and gets 144rwkw (thats with turbo and manifold only no injectors or nething)
  25. #25
    VL
    Jul 2005
    SA, Mount Gambier
    Clint, did he have a red skyline? he also ran no power steering and a minispool? cant rember his name but i brought some springs and shocks off him for my old r31.
  1. SXC VL's
    By Torquen in forum General
    Last Post: 16-11-2006, 03:23 PM
  2. 19's and vl's
    By jonno_12 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-07-2006, 11:27 AM
  3. which VL's come out with LSD ?
    By kiwigem in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-03-2006, 05:09 AM
  4. VL's and insurance
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-10-2005, 05:37 PM
  5. break set ups in vl's??
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-10-2005, 05:30 PM
