i gotta take out front and back windscreens cos there is lots rust behind them, how do i take them out? and will i crack them?? i dont really wanna pay sum1 to do it but if i have to i will, how much would they charge? cheers
there urathatind in. theres a sertan air powerd tool designd for the job, which involves cutting from the inside of the car, once you cut all the urathin off it should simply lift out
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
I would be getting a quote from a car windscreen place, the rust is common, it seems the area was left as bare metal by holdens, if the rust is bad, new metal may need to be welded in
or cut your seal and replace it.
get a thin piece of wire and poke it through ethier side of the silastic and use the wire as a saw and cut it out. easy as pie takes 5mins
Basically just cut it and then push it out from the inside. I've heard of people easing the pressure on slowly with their feet and working their way around.
But The wire and cutting seems like a good way.
Hint: Most trademans drink, offer a windscreen bloke a few drinks to do it for you.
Hint:A sixpak just wont do it.
cheers thanks fellas i shall try that, the flammin dudes at o'brien glass quoted me $204 for a new windscreen installed.
$204 is pretty good. that would be my plan.
