Results 1 to 8 of 8
Thread: whats gone wrong
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Default whats gone wrong
    my car was running perfect except for a miss at idle when in gear. didn't drive it for 2 days now it won't start. cranks over fine. theres no spark from coil lead though. changed coil but still no spark. could it be the CAS?:b:
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up gone wrong
    Yeh sounds like CAS, you can check it with the codes 4 the ECU even if it won't start...
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    the ecu was showing the fault code weeks ago when i checked it. could it be a fuse? its too dark to check now, don't have a torch.
    Jun 2005
    South OZ Adelaide
    I would check that first and any related connections, I cant remember if there's a relay 4 the ignition ....
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    just replaced the CAS. the car starts but runs like a dog. it has to be at full advance just to idle. but it won't do anything BUT idle. plus because its so advanced its spitting fuel into my headers and cooking them. maybe i should reset the ecu?
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by bangers
    What things did u do to replace the CAS???
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    yay....i fixed it. the manual said to line up the marks on the dizzy gear and housing, but in doing this it places the rotor above the number 1 cylinder contact, i removed the dizzy and put the rotor down abit so the marks were a little out of alignment and now the rotor fires on the 1st cylinder properly. now it doesn't need to be advanced at all. I reset the ecu to be on the safe side too. yay for me
    Jun 2005
    South OZ Adelaide
    Talking It's all go
    Hey thats better and now is all cool, nice..
  1. whats wrong????
    By SKITZ6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2007, 12:39 PM
  2. tell me whats about to go wrong..
    By Fritz_ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-03-2007, 08:28 PM
  3. whats wrong?
    By damo15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2005, 08:59 PM
  4. whats wrong with my car :(
    By Bex in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2005, 11:24 PM
  5. Whats Wrong With My VS??
    By vscomm_2004 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2004, 06:01 PM
