hey, after heaps of research, i will be going turbo with my engine and do a cam swap later. the only problem i have is the computer.i dont want to spend $800 on a computer that does lees then my PC. a mate offered me his computer from his turbo r31 skyline. Would this work??
yep.. as long as the plugs fit![]()
I wonder what those scales on the top right side of my posts do...
If his skyline is an aussie spec, i would say he originally took the ECU from a VLT because the aus specs never came out in turbo (afaik) and the ecu should go into your VL no probs. If its the jap spec skyline, i dont think it would work because they run an RB20DET.
Worth a try anyway, takes about 5 minutes to connect.
That why you need to spend more to get a better computer.Originally Posted by thestash_16
