Results 1 to 5 of 5
Thread: Computer Codes????
    VL86Berlina Guest
    Default Computer Codes????
    Hi guys... the other day i ran the computer in diagnosis mode to find out whats wrong with my car and it gave me these numbers:
    -23
    -24
    -31
    Are these the things that are wrong with the car and if so how do i fix these???
    Any advice would be great.. thanks
    James
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Default codes
    Quote Originally Posted by VL86Berlina
    -23
    -24
    -31
    James
    you don't need to fix any thing these codes are what you get when you test and dont do the full test..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    EF Almost Turbo
    Jun 2005
    how do you do the test?
    Thanks
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    VL86Berlina Guest
    hi....under the left kick panel...( panel near feat on passenger side) is the computer.
    gently turn the screw all the way anti-clock wise, then turn the key on and turn all the way clockwise.
    there will be 2 little led's that flash which indicate a code for a sensor or engine component. there is usually a few seconds between codes.
    1 flash red=10
    1 flash green=1............so for e.g 2 red and 1 green equals 21.
    Im not positive on what the computer tells me.... but if u have a manuel u'll be set!
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by DazzlerVL
    Thanks
    If you still need to know how I'll send you a copy of what I sent to VL86Berlina
  1. Computer Error Codes
    By pcp20us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2008, 06:26 PM
  2. Computer error codes.
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2007, 07:15 PM
  3. Computer Codes
    By VSBerlina95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2006, 08:37 PM
  4. vl computer codes
    By cuckoo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-07-2005, 02:24 PM
  5. Vx Computer Codes
    By VXWAGMAN in forum General
    Last Post: 09-01-2004, 09:47 AM
