Today, i found i am unable to lock or unlock my car from the inside of the passenger side door. the button just slides across without doing any thing, would some one please be able to tell me how to fix this and if its a big job..
thanx Nic
Behind every Great chick, Is a guy checkin' her out
pull the door trim off and have a look. the rod may have dropped off the locking mechanism.
ohh god, watch me post back here with my door in peices and me stuck for help.... Ill have a go tho :P
No probs you can do it..Originally Posted by vlfury
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
once you start looking, things can sometimes be quite simple to fixMy door lock is a bit dicky, but just having a look and a play with the mechanism always helps
i'll start looking but im too scared atm lol
Is that a tiger or a pussy cat on ur avatar?? lolOriginally Posted by vlfury
its a little pussy :P
but i am a chick thats gota count for some thing
girl torque is a chick, dose taht make any differance, and dont say shes from sa so it dosnt count coz we do down hereOriginally Posted by vlfury
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
so it's not a meat eater?Originally Posted by vlfury
would u happen to have central locking?
cus i do.. and this happens to me, i had to break in acouple times to many lol.. i ended up bending the rod that moves the sliding lock part, its never been save since...
i lock it and come back 15.. 20 minutes later to find it unlocked :| lol
i just removed the relay thingy, but its just a matter of bendin the rod into the correct place.. theres also some black boxes on those rods they have springs inside so it could be that too .
lucky i have 2 doors of a vb that has central locking im just gonna take that stuff and put in mine to fix it all up
have fun and good luck! lol
nah just an exec, no central locking on her
go on do it! I did mineI even did my central locking
& my solex locks...
that was painful!
Honestly I even got my girlfriend to give me a hand one day told her to pull off one lot of door trims while I did the other side of my BF's car to get speakers out... she knows nothing... lol & she was so suprised & proud of herselfthat it was so easy! It really is piece of piss
Add me to MSN.... Ill step ya thru
D.
lol thankx
Hey fury,Make sure your window is up first. Get a star screwdriver and remove the arm rest, get a flathead screwdriver and pop off the lock surround and handle surround, take the flathead screwdriver and pop off the window winder and the black triangle where the mirror is (carefully). Put your fingers under the doortrim (at the bottom) and feel for the clips and gently pull the doortrim from the door (without breaking any clips would be ideal). then you will have all the clips out slide the trim up and off the door.
You will then see a plastic sheet covering the guts of the door just peel it back enough to see how it works and if you get confused pulling the other door trim off will give you an idea of how it all looks inside.
GL with it aye.
Originally Posted by Countess
sorry what.... sweet mother of.....we have ourselves a real lady...woohoo![]()
just muckin Countess. i wanted to see if any of the young ones got stirred up with you talking about your girlfriend. i figure she is a girl who is a friend as you have a BF and all. never mind....me tired and silly.
oh i like it. i like it alot. what guy wouldn't. it takes alot more than that to gross me out. i've had my share of threeways.
Originally Posted by ucwepn
i'll have a go on the week end, i think ur still on my msn so if i get stuck im coming to ask you LOL thanx for the advice
the plastic lock from the inside has snapped off the wire..
are u able buy other ones to put on:S
