Results 1 to 8 of 8
Thread: Dim Lights...?
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    Exclamation Dim Lights...?
    hey ppls, i've had this for a while so its time to fix it...
    ALL my lights are dull... My dash lights are dull, and my headlights are dull, they look fine whenu look at them, but i can barely see stuff on the road.. lol
    i was thinking i wouldnt be the globes would it?
    I was thinking of buying new ones, but i dont wanna waste money if it aint the globes that has the problem..
    For the dash, i changed a couple of lights to blue, but its still dull, and these lights are very powerful.. so im thinkin its somethin else..
    Also, could someone help me on the location for the earth wiring for the front lights, i got some weird stuff happenin to them.. :b:
    I wonder what those scales on the top right side of my posts do...
    vl berlina wagon 6cyl
    Jul 2005
    with the headlights you get a buildup of muck inside on the glass lenz and the silver reflector part
    the light unit can be taken apart and cleaned but the silvering is usually damaged by heat from the globes, keep mineral turps away from the silvering
    the parking light holder is usually spoiled by the heat and a replacement isnt available
    both genuine and non genuine headlight units are available, non genuine in melbiurne from SSS autoparts
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up Dim
    How many volts at the battery when the car is running??
    Less than 13.5v and it's proberly ur alternator..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jul 2005
    never thought of it being my alternator.. i'l have to check it out.. i checked out new headlights and they want $97 each for genuine ones.. so thats pretty good.. but i'l check the volts first...
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I bought the phillips globes that are around $45 and they are a strong pure white and a massive improvement over the candlelight type globes that were in it, also taking the lenses off and cleaning them in the sink will help slightly. Also the silver stuff inside the headlight is also usually the culprit (the aftermarket ones mostly) but even holden genuine headlights can lose they're reflectivness after 20 years or so.
    ========My Statesman 20's Mafless and 3.9's========
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    i have the same problem but my alternator is charging really well, but sometimes when i rev it they go brighter wat could it be
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    as all above have said maybe lenses and reflectors old and dull.
    but seeing how you have mentioned the dash lights and other lights are dull and vlwalky is saying when he revs they go brighter, the main cause for this is bad earth, you need to remove all earth points e.g. the engine block, the body near the battery and the battery leads and the alternator connection clean all of them and replace them making sure all are clean and secure.
    other causes include faulty and/or low charged battery, faulty regulator.
    Nobody wants to play with me
    Nackerz's Avatar
    Jul 2009
    okies cheers mate
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. BUY or SWAP:clear ute/wagon lights for stock lights
    By Boonz in forum Swap / Wanted to Buy / Trade
    Last Post: 05-01-2007, 03:33 PM
  3. Replies: 3
    Last Post: 26-10-2006, 05:43 PM
  4. No interior lights, dash lights or elec windows vk
    By ported in forum Electrical Wiring / Questions
    Last Post: 18-09-2006, 05:10 AM
  5. No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 10:36 AM
