Results 1 to 5 of 5
Thread: aircon leaking into cabin
    Boonie Guest
    Default aircon leaking into cabin
    Hey guys, I got my aircon regassed the other week and all is as cold as a mother inlaws kiss now. The only drama is that it is leaking quite badly into the passengers foot well. does anyone know where the drain exits the car so I can see if its blocked?
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by Boonie
    A rubber tube passanger side under the car...
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    Quote Originally Posted by mag
    Under car, then y be leaking inside...mine is same...Water leak, but also gas leak aswell from compressor, are these just seals or is the compressor fu<ked cuz i won't be getting it fixed then.
    Boonie Guest
    Im looking for the tube because I reckon its blocked and overflowing into the passengers side of the car.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    if you pull off the plastic cover under the dash ,on the passengers side ,you will see a rubber tube, on the right side of the aircon box, pull this off and clean it, out be ready to catch eny water in there
  1. blocked aircon drain - leaking in the car on drivers side
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2008, 07:10 PM
  2. Aircon leaking VS
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2007, 12:17 PM
  3. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  4. blocked aircon drain - leaking in the car on drivers side VR
    Last Post: 24-12-2006, 05:42 PM
  5. A/C leaking water in cabin
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 06:24 PM
