Results 1 to 14 of 14
Thread: hey much does the trans hold?
    492 Guest
    Default hey much does the trans hold?
    hey just wondering how much exactly does a VL 1988 Auto transmission hold?? i've put 1-2 litres in but trying to find out... thanks
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    the manual says 4-1/2litres from memory. just leave the car running and keep checking it and topping up til full.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    If its overfull it will just pump out the excess
    ========My Statesman 20's Mafless and 3.9's========
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    Quote Originally Posted by ucwepn
    where to? mine just gets sluggish in changes etc. not the same box though.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up Trans Fluid
    Quote Originally Posted by 492
    2.5lts after the pan has been removed..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i just consulted my manual and it says about 5litres of dexron llD. Seems abit i know. but then the diff takes about 2 1/2 litres.
    vl berlina wagon 6cyl
    Jul 2005
    if filling the auto when cold it should only be at the add mark on the dipstick as the fluid expands a lot when hot
    you can undo a hose to the radiator cooler to pump excess out
    anyone ever sucked the fluid out using a tube down the dipstick tube with a pump?
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    nope, wouldnt suggest it either. just follow the book and check the levels. the slightest bit too much wont hurt anything. way too much will be a pain in the bum.
    always check the box levels with the car in park and the engine running.
    Jun 2005
    South OZ Adelaide
    Default Trans Fluid
    Quote Originally Posted by mag
    same as other oil companys amounts/lts as shown here
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by harry3
    Yeah tried it once but I had a bad pump. Didn't work very well hehe. Ended up undoing the pan a bit to let some out which got really messy! :my:
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by bangers
    The diff holds 1.7 lts of limslip 90..
    VYSHSV8's Avatar
    VYSHSV8 is offline **** happens
    VYII SV8 M6
    Dec 2005
    If you put 5ltrs of trans oil in you will over fill it by about 2 ltrs you gotta remember that is including the torque converter as well, when you do a trans service you in general only drop the amount of oil in the pan and that is about 2.5ltrs the converter holds the rest and wont drain unles you take out the box and converter and empty it which cant be done in the car unless you crank it dry which is not reckomended ok..
    Jul 2005
    many auto trans problems are caused by the fluid level being too high, its always the first thing that should be checked for any problem
    its not unknown for the wrong auto trans dipstick to be fitted in the shop either, giving a false reading
    with some engine dipsticks, the retaining stop part can fall off, resulting in the distick going in too far, the resulting false reading has caused severe engine damage in 1 case I know of
    1986 vl commodore
    Jan 2010
    Default gearbox
    strating off in 2nd on my vl feels like its slipping start off in first and drive pikups good any ideas
  1. wont hold 2nd gear burnout
    By tbblitz in forum V6 Development And Modification
    Last Post: 18-03-2007, 08:45 PM
  2. What do your gears hold out to?
    By jessyvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2005, 05:01 PM
  3. Next Monaro on hold
    By Ratty in forum General
    Last Post: 07-04-2005, 12:07 PM
  4. how much does the Vk Fuel tank hold?!
    By frantic in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-09-2004, 05:01 PM
  5. Will It Hold Up In A Turbo
    By NVMYVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-02-2004, 09:09 PM
