Results 1 to 10 of 10
Thread: where to start
    dobbie Guest
    Talking where to start
    im replacing my whole drive train in my vl im thinkin of putting a nine inch in dont know wat to do with my auto box deffently shift kitted but its going to have to be made s#@t loads more tuff any ideas?
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    what engine do you have? i wouldn't worry about a 9 inch unless you have a worked V8. They can use more of your power as they are a heavier diff. if you want to stay auto then it depends on your engine power again. shift kit or different box all together. if you want to go manual then a rb26 (?) box i think can run 370kw before needing to be strengthened.
    dobbie Guest
    i have a n/a rb30 but it will be getin a alot of work done, not much spared, so hoppin for about 400 horsies thats why i was thinkin of a nine inch but the box will stay auto do u know how much the standard box can handle with work done to em
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Yeah go with a stage 2 shift kit (they don't make them for vl's so just get a bigger valvebody fitted), bigger fans and clutches fitted will help too (and maybe a big custom trans cooler). Go for a 28 spline vl turbo diff, they are well strong.
    ========My Statesman 20's Mafless and 3.9's========
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    like bangers said the 9 inch is a waste of time. youll be amazed at how strong the diff you have is, then when you have all this power (??) youll know what to get based on the gains.
    Turbo lsd will hold on for a long time.
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by dobbie
    www.keas.com.au
    Speak to Paul, he will put you in the right direction.
    dobbie Guest
    yeah i origanally thought of the turbo diff but the cost double 2 buy n rebuild the turbo would be ideal tho
    VL Calais NZ Guest
    I've got a mate who was running the 25 spline std 3 litre diff behind a manual 470hp blown 5litre for awhile. Admittedly, it did snap an axle after awhile, but you would be amazed at the abuse it took.
    You would have to have some serious horsepower, or changing gears pretty hard to be hurting these diffs. At the end of the day I spose it comes down to what you want to spend?? $15 to $40 for a 25 spline axle, or between $1000 and $2000 on setting up a 9 inch that you may never reach its power potential.
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    9 inch would cost more to setup.....and if ya chasing 400 horsies u gota have abit of money to spend anyways lol ud be surprised at the vlt diffs they are damn strong ...... and get keas to rebuild ya box for u they do a top notch job
    dobbie Guest
    yeah the nine inch i was lookn at was a swap for a mr2/corrola charger, already set up for commy so its a pretty good deal
  1. When VN S2 Start?
    By pro_gmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2006, 05:01 PM
  2. Help, VS won't start
    By Matilda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2006, 08:34 PM
  3. Didn't Want To Start
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2005, 03:14 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
