Results 1 to 4 of 4
Thread: Replacing Odometer
    RankONE is offline www.warfilms.biz
    VL
    Jan 2006
    Default Replacing Odometer
    The odometer in the tacho dash i put in has stopped working. But the old one worked fine. So how do i swap them over?
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    Pull out the cluster, remove plastic front, slide the reset button off (just pull and twist, carefully i'd assume), there are 2 little flat screws in the front; undo them and the cover should come off...There should be two screws in the back which holds it in place; undo them and out comes the odometer/speedometer. At this stage u can actually wind your clock but i wouldn't advise it if you have already replaced the cluster and didn't change it then.
    Jules86's Avatar
    Jun 2005
    Rockhampton
    As ive notcied as putting my old cluster back together (was lying in pieces in my room). You'll have to remove the top part of the cluster by the five screws at the top back. This will give you access to the front screws; some which were hidden (8 total screws in for the clear cover i believe) once this is removed then you can access the insides. Do the steps above to get it out, and use a fork (or something similar) to lift the dial off (take care). And when putting it back on you might have a bit of trouble, took me a couple of goes to get it to rest back on the stopper, (will be very inaccurate if it doesn't rest)...Im 3 km out but that was testing with another car not a radar.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    yep what jules said, replace the whole speedo then you can keep your original K's. doesn't take long maybe 30 mins give or take.
    ========My Statesman 20's Mafless and 3.9's========
  1. odometer..
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2007, 09:05 PM
  2. VB Odometer
    By kman31 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-06-2005, 09:06 PM
  3. vr odometer
    By sterutsterut in forum General Discussion
    Last Post: 27-01-2005, 01:32 PM
  4. VN Odometer
    By mechanic22 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2004, 06:08 PM
  5. odometer
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2004, 09:39 AM
