Results 1 to 12 of 12
Thread: What should I do?
    nsladden's Avatar
    nsladden is offline GET UTED
    1992 Holden VP Ute S 5.0L & 1989 Holden VN 5sp Wag
    Sep 2005
    Murwillumbah
    Question What should I do?
    I need help with the following things for my VL RB30
    +Is there a higher flowing allternative to the stock AFM?
    +How would I go about fitting an XF throttle body to the RB30
    Are there other easy financally friendly options I could use?
    Im sorry about the crudity of this thread but im in a hurry
    Thanks Again
    JBVL is offline Retired Dirtbiker
    VL 1987
    Dec 2005
    Australia, QLD
    the only thing i know of doing to the stock AFM to get a bit more flow is remove the mesh either side of it although ive heard of cases where ppl have done this and its stopped working, i think its because the front mesh displaces the air evenly so it gets an accurate reading, if thats a problem for you just remove the back one (the engine side).
    There is some minor modification that needs to be made to the intake manifold before the XF TB can be bolted on. Im not exactly sure whats involved in this although im pretty sure its been covered on here so do a search, calaisturbo.com might also have some information about it. I do know it can be difficult to get the TPS right with the auto's.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Hi , if you have no other mods to your engine you will not notice any difference in fitting an xf throttlebody. Go and buy a k&n filter then you can take the AFM mesh's out because the filter has its own mesh.
    There is no point upgrading the throttlebody and afm of you use the standard intake pipe and airbox. If you buy an aftermarket ECU you can get rid of the AFM all together.
    ========My Statesman 20's Mafless and 3.9's========
    nsladden's Avatar
    Sep 2005
    Murwillumbah
    Nah I dont have any other mods but I can get the TB for free and I am planning to mod it now that its running again. Are there any parts I could take from a VL Turbo and fit it to the motor???
    With the intake pipe could I somehow make my own or should I look out for a ceramic coated one?
    Oh and its an Automatic SL if that helps. Thanks
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by ucwepn
    what sort of ECU is that? if i got rid of the AFM that would be one less thing to worry about failing.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    an ECU that has the MAFless option, just something I have heard people talk about, i'm not 100% on it myself.
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    yea if u get an aftermarket ecu in most cases u can get rid of the afm alltogether... put ya looking at 1100+ for that......as for the xf throttle body not to much is involved as long as u got a dremal and some mechanical kno how.......u do need to renforce the bit where the throttle body bolts to with more weld as u will need to grind a fair bit out to come flush with the size of the xf TB....and be sure to get a series 2 xf throttle bodie as it far easier to hook up
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by VLDavo
    is there any major visuals to help pick out a series 2 throtal? as i might get 1 this weeknd from the self service wreakers
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Mar 2006
    Oct 2005
    ok so thats the size diffrants but is there any easy way to tell the differance between a series 1 xf throtal and a series 2 xf throtal?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Mar 2006
    series 1 dont look like the one pictured .... look for the 2 tabs the green and red and that should send u in the right direction
    VT SS S2 A4
    Aug 2005
    My Autronic does not use the AFM or O2 sensor.
