Results 1 to 7 of 7
Thread: how do u take door trim off?
    boostdvl69 Guest
    Default how do u take door trim off?
    i cant figure out how 2 take the door trim of my 86 vl comodore? can some1 please help
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    The arm rest has two screws - Phillips head screw driver to remove that. The surround for the handle and lock mechanism just pop out with a blade screwdriver to lever it off. Then its just a matter of getting something flat and wide and wedging it in between the skin and the door. And levering. Once you get a small part you will see the clips that are there every 10-20cm or so.
    Oh the mirror cover may have to get levered off aswell.
    I think thats all.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    front or back?
    front:
    -phillips head to unscrew the armrest.
    -push the panel in as much as you can, a clip holds the window winder on, a spoon will help flick the pin out, however watch where it flies cos they fly a long way!
    -lock and opener surround will clip off. careful that you dont snap them. mine never snapped but ive heard some peoples do. again, the spoon will do this nicely.
    ibit around the mirror adjustor from memory just pulls off. again careful of snappage.
    -if you have a speaker, remove it somehow!
    -from the bottom of the trim, work your way around pulling gently. it will pop off then simply lifts off the window channel.
    back:
    -see front, minus the bits the back doesnt have!
    boostdvl69 Guest
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    after you have removed all the attachments be careful not to break the clips that hold the trim to the door. squeeze your fingers under it and you will feel where they are and it makes them easier to pull out.
    ========My Statesman 20's Mafless and 3.9's========
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    also be carefull of snapping the backboard of the door trim coz they do get brittle
    boostdvl69 Guest
    thx for all the help i took all the door trims off today it was pretty easy and i didnt break anything lol
  1. VT door trim
    By totality in forum Car Audio
    Last Post: 17-01-2009, 12:31 PM
  2. L.E.D's in Door Trim
    By Ghost79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2006, 01:18 AM
  3. door trim help please
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2006, 04:54 PM
  4. Door Trim to SL\E
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2006, 07:18 PM
  5. VL Door Trim
    By bangers in forum Swap / Wanted to Buy / Trade
    Last Post: 14-03-2006, 08:49 AM
