Can anyone give me some advice on what cam to run. i was thinking i should upgrade ignition coil and get larger leads, is this neccisary? what sort of performance gains do u get from a stage 2 cam?
It doesn't really give gains, what it does is shift all the power to a certain rev range. Say you want all the power between 4000-5500rpm It will be really strong in this rev range but a bit sluggish everywhere else. A good rev range for an rb30 is from 2000-3500 rpm which is great for use on the street. you will need a Hi-stall to match to get the full benefit and performance.
Originally Posted by ucwepn
high stall? go on
Half a carton and still going!!! Now thats Economy
yeh i had a feeling i would need a stallie. just like a 1500 or 2000 stallie should do im thinkin with the cam running prime at 2550-3000rpm?
If the cam starts at 2550-3000 so should your high stall converter..Originally Posted by DVS87
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
i think i reacall some one saying it had 1800, but not positive.Originally Posted by ucwepn
what happns with a manual is a stall convertor needed?
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
it's then called a clutch...Originally Posted by VL Berlina 5speed
is a clutch that thing on the end of my left foot? the one where i lift it quickly it makes my car kick out??Originally Posted by mag
so basicly a high stall converter is a clutch (stall convertor) upgrade for a automatic. would it be recomended to get a newer lighter clutch if cam work is done to a manual?
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
Forget the last bit, and NOW a manule HAS a clutch(and It's the thing on the end of ur left foot) and you control what rpm is needed when you engage the clutch for take off..Originally Posted by VL Berlina 5speed
In a auto the Converter engages (like a clutch does) with the right rpm and away u go..
Nobody needs a high stall converter in their auto unless they have a perfomance camshaft FITTED..![]()
thats correct but alot of the time people want one in the bigher rpm range because you see, that way they can say yeah bro, i got the stallie up right where i want it...
a different cam can make more power or less, lumpier cam, more lift = more room for the air and fuel to enter the bore.
just a question i am thinking, the vl turbo has a different cam doesnt it, whats the difference between na and turbo.
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
a n/a stallie is 1500 an u do get more power from a cam, they allow more air n fuel into your car so some headers will help alot an if your puttin a cam in a ask the guy wat stalli will match im guessn a 2200
the chip should always match the cam so your pretty right there but the charger for a bit over a grand wat brand is that castlemaine rod shop do them for for bout $1800 i thinkOriginally Posted by ucwepn
cams are definately worth the money.. if you get the right one and a decent one.. ive got a camtech stage III cam.. comes on from 3000 - 7500 and does wonders with my turbo!
you lose torque with a lightened flywheel. it'll rev easier but won't pull as hard. eg you won't have as much pull off the lights or up a hill. but once you're going it'll get up the revs easier.Originally Posted by ucwepn
