Results 1 to 12 of 12
Thread: 4 ecu error codes
    VS executive
    Jan 2005
    Default 4 ecu error codes
    ok so i just checked my ecu codes and got these ones which is disturbing cos theres more than one of them. could some one explain them to me ( in dollars)
    VL ECU FAULT CODE LIST
    12 - Airflow meter (AFM)
    14 - Vehicle speed sensor
    23 - Throttle switch
    31 - System pass (everything ok) Non A/C models -or- A/C circuit fault in A/C models
    Half a carton and still going!!! Now thats Economy
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by VLACS
    Vlacs check your e-mail!!
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VS executive
    Jan 2005
    yeh i did that. is there a reason why i should?
    what ever you sent me got deleted cos thats the setting on my thing. changed now sorry
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Got it now?? Info 4 you..
    VS executive
    Jan 2005
    Quote Originally Posted by mag
    yeh i got it cheers buddy
    VS executive
    Jan 2005
    sorry i already have the codes and have checked the computer. i just need to knwo what they mean. the codes i said before...
    Jun 2005
    South OZ Adelaide
    Talking
    It tells u what they mean also..
    VS executive
    Jan 2005
    this one page?
    11 - Crank angle sensor (CAS)
    13 - Temprature Sensor
    21 - Ignition signal
    24 - Neutral switch
    32 - starter signal
    34 - knock sensor (turbo models)
    44 - System pass - A/C models
    your not referring to this are you?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    not possitve but vehicle speed sensor dont u have to travel faster then 10km/h to clear that off throttle switch is accelorating under load, afm might be meaing its not connected proberly or is stuffd
    not sure on the other
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Jun 2005
    South OZ Adelaide
    Thumbs up
    this one page?
    24 - Neutral switch
    32 - starter signal
    THATS the 1 yes
    VS executive
    Jan 2005
    yeh cheers. that part didnt help but conveniently the other part with how to do the test was quite good. so cheers
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Thats why I sent it to you...
    If you dont test it that way you will get code errors 4 things that ARE OK!!
    OK..
  1. VS V6 Error Codes
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 10:25 AM
  2. Error codes on Vs
    By PorterVs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 08:10 PM
  3. Error codes
    By Jaym in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 09:34 PM
  4. error codes 6 and 8?
    By Juzzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2005, 07:12 PM
  5. v6 ERROR CODES
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2005, 05:52 PM
