greetings
well here we go
1) my temp gauge is going crazy. car doesnt seem to be getting hot, anyway to fiz it?
2) i know this has been done and asked b4 but has anyone fitted one (with pics) and what power gain does the castle main rod shop supercharger give?
thanks
wat exactly is the temp guage doing ? is it going up and down rapidly
look on the crs website it has pics and so forth of the supercharger setup....the setup givesa around 150kw at the fly wheel......witch means u will go as hard as a stock vl turbo....... in my opinion its jus not the best option if u want power.....especialy for 1500...
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
yeah the temp is going up and down rapidly.
with the supercharger i just want down low power
check the connections for the temp sensor where the top radiator hose goes into the engine. because the vl tends to generate a fair bit of heat these connections tend to die and end up crumbling into nothingnessif these connections r fine, u may have a broken wire somewhere and u'll need 2 make a bridge cable with some small ally clips on the ends which will pierce the wire but not severe it. when u find a spot where the needle stops jumping the break will b between the ally clips
... best of luck
