i'm looking at swapping my exec dash cluster for the berlina as i'd rather have a tacho than a stupid clock that only half lights up. neway does ne1 kno wat the process entails? for example; is it a str8 swap or is their extra wiring i hav 2 run. also if i'm gonna need a wiring diagram or something i would b very gr8ful if u could provide them or a link to them. thanx guys!
Mark.
It is a straight swap and plugs straight in and will work with no modifications. For the oil pressure guage thats another matter and I wont get into that now but everything else will work. Check the back of the berlina cluster to make sure its an auto cluster (if yourcar is auto),you can tell by looking down into the back of the speedo for a small circuit board that will be visable from the top. If the cluster does not have this circuit borad and the car is Auto it wont kick down gears when you plant the foot.
Do a search there is a thread from when I did mine.
