Results 1 to 5 of 5
Thread: vl exec to belina dash conversion 2nd question
    87 VL Commodore
    Jun 2005
    Default vl exec to belina dash conversion 2nd question
    now that my last question has been answered can someone plz explain the whole low oil pressure thingy that ucwepn didnt explain in my last post?
    something about its a str8 swap for the dash cluster only their is a problem with the low oil pressure light??
    cheers
    mark.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by Milkman
    cheers
    mark.
    only thing i can see that need changing is the oil pressure sensor on the side of the block, its near the oil filter and is screwd in witha cable coming off it,
    think there was a differants in they blnas/calais types and sl/executive types
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    The thing with the berlina dash is that it doesn't have a low oil pressure light, it has an oil pressure guage and it will constantly read full oil pressure unless you get the variable oil pressure sender from a car that has oil pressure guage fitted
    ========My Statesman 20's Mafless and 3.9's========
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    The sender is there - You just need to bridge two cables and connect it up, the wire should be taped under the inlet somewhere - Blue wire as far as I remember, thats meant to run to the Sender.
    Thats my understanding of it.
    sed8's Avatar
    sed8 is offline commodore nut
    vr ute @ vk calais
    Feb 2005
    brisbane
    dashs without factory oil guages must run different senders as they must be earthed out type on sl's as when the berlina sports or calasi dashes are plugged in the guage goes of the scale so as others have posted the sender will need to be changed
  1. vl exec to belina dash conversion
    By Milkman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-03-2006, 10:32 PM
  2. vn exec dash wiring
    By glennk in forum Electrical Wiring / Questions
    Last Post: 12-02-2006, 10:42 AM
  3. VP exec to calais conversion
    By PANDO in forum General
    Last Post: 10-02-2006, 02:24 PM
  4. Dash Swap Over in VP eXEC
    By Dal VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2005, 06:36 AM
  5. Calais Dash in Exec?
    By TRYMY6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2004, 10:12 PM
