Results 1 to 14 of 14
Thread: Overheating
    Turbo_dreams's Avatar
    Turbo_dreams is offline MYVTSS98
    VT SS 5.0
    Mar 2006
    MLB
    Angry Overheating
    Hay people, just a quick one my vl keep's overheating , my oil in normal and i have takin the thermostat out and she keeps over heating i have a few holes in the exhaust which is being replaced other than those things are there any things i should consider please hekp!!!!!!!!!!!!!!!!!
    Jay
    Melbourne,Australia
    jayhcoffey@hotmail.com
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    May be a stupid question but have u checked ur coolant and that the piping isnt blocked
    :my:
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by Turbo_dreams
    well the most likely couse of ur over heating problem would be a fault in your cooling system (radiator) your radiator could be blocked by dirt and crud in the system,
    the best way to figger this out is but flushing the system, take the top and bottom hose of the radiator and hold a hose pipe in the top, water should be able to go out the bottom at the same speed it enters at the top and flush to clear water exits the other end, if it has problems doing this and starts coming out the top where ur entering it, you can presume its blockd
    and a new radiator is needed or a radiator specilest might be able to unblock it
    if the water flows free thought the radiator then turn the pipe on to the pipe which is connected to the thermostat and flush the motor, flush to clear water exits the other end. if it has problems then it could be internal or thermasta might be sezing
    BUT rember that if you do this u will have to refill the hole system with coolant and DONT FORGET TO BLEED THE SYSTEM or you could crack your head, (this happend to me because the bleeding valve shered off)
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VT SS 5.0
    Mar 2006
    MLB
    i have checked the pipeing and it is all clear it appears that the top pipe from the radiater to i think the water pump? it doesnt appear to have any water runnin through it i also flushed the radiater as u said last night but she stills over heats when car is runnin the thermom gauge doesnt sit on red but one notch before it could it be the w/pump and if so what happenes if the pump goes
    Jay
    Melbourne,Australia
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    squeeze your hoses. if they are soft then they may be sucking shut and restricting flow. for the radiator......if there seems to be heaps of crap in it then do a flush or take it out, lay it down and put coke in it, shake it around a bit, let it sit for a while, pour it out. then repeat process a few times.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Have you checked the clutch fan..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VT SS 5.0
    Mar 2006
    MLB
    Exclamation
    is that the fan located at the fron of the radiator?
    if not where cheers!
    Jay
    Melbourne,Australia
    Jun 2005
    South OZ Adelaide
    Thumbs up
    It's the huge fan with white blades..
    VT SS 5.0
    Mar 2006
    MLB
    Jun 2005
    South OZ Adelaide
    Thumbs up
    so is that on at all times or at a temp????
    It's on all the time but pulls through more air the hotter it gets..[QUOTE]
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    Even with a blocked radiator removing the thermostat will allow plenty of water to circulate throughout the system , even though on a fuel injected car you should never remove the thermostat as it plays havoc with the computer readouts and excessive fuel use. I'll bet the car has a blown headgasket on the exhaust side and the exhaust gases are super heating the water and I bet the water is being spurted straight out the radiator cap openning even before the water heats up. You should be easily able to have the vehicle running with the radiator cap off and no water boiling over the outlet top. If you can't run the car with the cap off then a blown headgasket is for sure!!! Whats called a TK Head check diagnostic tool would confirm. Good Luck!!! As they are an exspensive job to do!
    VT SS 5.0
    Mar 2006
    MLB
    Exclamation
    thanks guys i have put a new thermostat in again but a genuine part and she runs alot cooler but she sits a tiny bit over half wayon the temp gauge is that normal ?cheers
    Jay
    Melbourne,Australia
    VT SS S2 A4
    Aug 2005
    Why not take it to a radiator place and get them to test the temp it is running at?
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    At operating temp mine sits a fraction over halfway and my whole cooling system has been replaced or overhauled so consider it normal.
  1. overheating..
    By lumina01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2010, 04:07 AM
  2. Vn Overheating
    By SV3600 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2009, 03:49 PM
  3. overheating
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2006, 08:11 PM
  4. STILL overheating
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2006, 04:16 PM
  5. Is It Overheating Or What?
    By midnight.outlaw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2004, 07:49 PM
