Hay How Do U Know When Your Water Pump Has Gone ,was Happens To The Car?
Jay
Melbourne,Australia
jayhcoffey@hotmail.com
it overheats. if the bearing is gone you'll hear a whine or a rattle. or it leaks water out the bottom which then follows the sump gasket around the engine which can be misleading.
also check to see if there is movement in the waterpump pulley. that'll indicate a worn bearing.
And also movement in the clutchfan. It should not move around much at all.
yup best way (apart from the noise it'll probably be making) is to check for movement. Take it from me - if it's gone - replace it asap! We've had a metal blade come off a HZ and rip through the radiator and lodge it'self in the bonnet....
