Results 1 to 6 of 6
Thread: Gearbox Torque settings??? anyone?
    AccrossTheDitch.co.nz Guest
    Default Gearbox Torque settings??? anyone?
    Hey people does anyone out there have a workshop manual on hand?
    If so can you give me torque settings for bell housing to engine, flywheel to crankshaft and pressure plate to flywheel. Its for a VL 2.0 manual gearbox.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    OK this is from gregory's and is the MF5 and ME7 transmissions.
    *reverse lamp switch 29nm
    *selector housing bolts 18nm
    *selector return springs plugs 29nm
    *reverse check sleeve bolts 5nm
    *extension housing to carrier plate 20nm
    *bearing retainer carrier plate 25nm
    *drain and level plugs 34nm
    *front bearing retainer 21nm
    *detent and interlock plugs 25nm
    *mainshaft nut 167nm
    *layshaft nut 127nm
    *detent bracket to carrier plate 59nm
    *clutch housing to engine bolts 49nm
    *clutch housing to engine reinforcing bracket bolts 40nm
    *transmission crossmember to underbody 51nm
    *mounting bracket to transmission crossmember 40nm
    *rear mounting to mounting bracket 25nm
    Hope this helps
    ========My Statesman 20's Mafless and 3.9's========
    Default Cheers!!
    Hey thanks man,
    That helped.
    Is there anything in the clutch section of your gregory's for the:
    Flywheel to crankshaft torque settings? And or
    Clutch pressure plate to flywheel torque settings?
    :my:
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    *pressure plate to flywheel bolts 29nm
    Have looked all through the book and can't find the crankshaft to flywheel settings. Gregory's is a shit book but its better than nothing.
    Default Thanks again!
    Hey thanks once again,
    Yeah I know what you mean when you say that Gregorys are useless!
    Ive got a VB seriers Gregorys and its soooooo disorganised!
    Fairly useless if you ask me!
    Cheers: Big Juss.
    MikeVXSS's Avatar
    MikeVXSS is offline !!!GO TIMMY GO!!!
    VX SS 5.7
    Oct 2005
    Bunbury, W.A
    see not all aussies are arseholes.
    BAAAAAA
    I love this forum??
    you just saved that guy 40 bucks or what ever it costs for a manual.
    did i mention i love this forum??
    Ash to Ash
    Dust to Dust
    Fade to Black
    ....The Memory Remains....
    ..RIP TIMMY..
  1. 8 Bolt flywheel/flex plate torque settings?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:23 AM
  2. torque settings?
    By vk202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-05-2007, 07:34 PM
  3. 5.7L Torque Settings Required
    By davus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2006, 01:21 PM
  4. Torque Settings for RB30
    By 610 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-07-2005, 05:08 PM
  5. torque settings
    By atreyu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2005, 01:15 PM
