Results 1 to 5 of 5
Thread: pinging
    tougHnA Guest
    Default pinging
    how do u exactly no wat to listen for when a car is pinging and wat is it i dont no wat to listen for....
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    i always thought it was like tappet noise but its more of a tap/knock than a ping?? it mostly happens when first starting the car as there is no oil in the top of the motor until its pumped up there. hence the noise. This is why a good oil is best to reduce the friction and wear of the part = less noise!! hope this is a help, but i maybe wrong.
    .:Blown VT V6, DAJ37:.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    incorrect fuel or low octaine
    inginion too adv
    pinking/detonation occures underload at low revs
    it ratteles the valvetrain not good.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    Default *yawn!*
    Sorry guys! been out of the loop for a while due a lack of stability in living/working arrangments. But back on the scene with a new beast to match.
    Ahh detonation. It's one of the things i teach aspiring student pilots about in Aircraft Tech lectures. Yea, it ain't a good thing, valve train rattle will be the least of your worries. Destruction of pistons and heads is quite a likley scenareo, trust me i've done it.
    Causes include...
    * Overheating
    * Use of too lower octane fuel
    * Weak/lean mixture
    * Improperly advanced timing
    * Pre-ignition
    Pre ignition is a problem in itself and will occur if valves are worn, spark plugs are too hot, or carbon hot spots build within the combustion chamber.
    If you suspect detonation, the first thing i'd try is a bottle of octane booster or higher octane fuel. Followed by checking the timing. If you suspect a lean mixture, you may want to check out the dirty old AFM.
    Turbo models of course, have a knock sensor fitted so problems should not arise.
    Mike.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by jetspin_vn
    Causes include...
    * Overheating
    * Weak/lean mixture
    * Pre-ignition
    Mike.
    Thats spot on it smashes rings too!!
    It sounds like metal bits and it's an uncontroled burn where as normal ignition
    is a smooth burn..
    If bad enough it's like letting someone loose with a hammer in ur engine..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
  1. Pinging
    By unregistered in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-03-2006, 12:52 AM
  2. pinging
    By skb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2006, 11:33 PM
  3. pinging
    By chris_1987_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-11-2005, 12:29 PM
  4. VR 5L pinging!
    By calais5l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2004, 08:49 PM
  5. Vr Engine Pinging
    By CSD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2003, 11:52 PM
