Results 1 to 11 of 11
Thread: battery drain
    shamden22 is offline shamden22
    vr executive
    Mar 2006
    traralgon
    Default battery drain
    hey does anyone know what would cause my vl to go through batteries every couple of months the alternater light hasnt come on and it runs fine then all of a suden its dead
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    either stuffed alternator........or if u have a sterio the amps might be draining the battery .......also check all ya conections and so forth
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    If you have changed the battery then it can't be the battery, it must be the alternator. or you have a power leak somewhere.
    ========My Statesman 20's Mafless and 3.9's========
    vl berlina wagon 6cyl
    Jul 2005
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by harry3
    check the glovebox and boot light, if jammed on they will be hot
    also volt test the alternator make shure it's above 14.2v
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    Girl Torque's Avatar
    Girl Torque is offline VL Calais 5L
    VL Calais.. etc
    Sep 2005
    SA
    yup you definaetly have a leak somewhere.. this can be a bugger to find too! See what you can do yourself, and if all else fails, speak with an auto electrician (with wallet in hand..)
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by shamden22
    Your alternator maybe cooking your batteries, like by belting in 16v+ and buckling the plates inside until it shorts them out-dead batteries..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    rx3 madman Guest
    Default Battery Leak
    Through my experiance, Check the earth point is 100% if there is any increase in resistance then the circuit will be degraded and chaging will drop.
    The alternator powers the electrics while the car is running so it may seem fine but the excess that would normally go to charging the battery will be lost due to the regulator dropping back the voltage.
    a good practice is to run a couple of other 6mm earth strap cables from the block to the chassis, this ensures proper earthing.
    check out all the suggestions and see how you go.
    G
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by mag
    valid point
    Powered By Garrett
    Jul 2005
    if the battery is being overcharged, you will also need to be adding lots of distilled water
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    yeah, chances are that you just have a bad alternator, or regulator. chargign voltage is it too high. try this, check ther voltage after you turn the car off and then check it before the next time you drive and see if it has changed. if it has, then you hasve a power drain, check it 5 minutes after you turn the car off
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
  1. question about amps drain on battery
    By mattgreen in forum Electrical Wiring / Questions
    Last Post: 12-01-2008, 08:53 PM
  2. VX Battery Drain problem
    By Xenon3d in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2006, 09:31 PM
  3. battery drain
    By fitzy2005 in forum Electrical Wiring / Questions
    Last Post: 13-05-2006, 08:53 AM
  4. VX Calais V8. Battery drain
    By alanb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2005, 10:27 AM
  5. Coolant Drain
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-10-2004, 05:41 PM
