Results 1 to 6 of 6
Thread: RB30 and 25 eng info??
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Default RB30 and 25 eng info??
    does all acc. from a rb25 like water pump, oil pump head etc bolt straight onto a rb30 block?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Hmmmm tricky question, there is almost 10 years difference in their release so I would say probably not.
    Bex would prolly know,
    Yo Bex
    ========My Statesman 20's Mafless and 3.9's========
    Apr 2006
    Apr 2006
    sed8's Avatar
    sed8 is offline commodore nut
    vr ute @ vk calais
    Feb 2005
    brisbane
    water pump and oil pump are the same they are the same block different bore fitting accessories onto the motor is harder i did the rb20 transplant and had to fore go the air con as the power steering pump sits lower apart from some better oil parts the head fits but requires the oil feed to the head needs a little attn and i think you need to remove one of the dowels when its all said and done it fits
    Apr 2006
    ah too easy cheers bud!
  1. Nissan RB30 V Holden RB30???
    By neatvl86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2011, 01:08 AM
  2. Rb30?
    By Jethrow666 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-06-2008, 07:13 PM
  3. RB30 with RB20det head. Info Plz?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-02-2007, 12:10 PM
  4. rb30 info??
    Last Post: 23-09-2006, 06:36 PM
  5. What does the RB in RB30 mean?
    By HSVenforcer in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-04-2006, 10:32 PM
