Results 1 to 11 of 11
Thread: Misfiring?
    VL 5-speed
    Dec 2004
    Default Misfiring?
    Dont know much about misfiring, but i think i may have a case of it.
    When the revs are relatively low (especially on take off) the car is jerky until the revs hit about 2500. Is this misfiring?
    It was serviced only a few weeks ago, but i forgot to mention it to the mechanic and he must not have picked up on it.
    How do i fix this? is it my leads?
    I have no idea how to do those computer tests so dont tell me to do those.
    What else could this be?
    Thanks all.
    vl berlina wagon 6cyl
    Jul 2005
    start by looking at the distributor head and rotor which may just need cleaning inside
    VY SS Wagon
    Mar 2006
    VL 5-speed
    Dec 2004
    How do i check my distributor head and rotor? and what do i look for?
    Sorry i dont know a lot about my vl
    Yeh the problems slowly getting worse.
    albino1986 Guest
    hey i had the same problem with it misfirng, took it to the mechanic, he replaced my dizzy cap and rotor, that fixed it quiet substancially but it came back, took it to an autoelectrician he replaced my CAS plug and now it works fne havent had a misfire since *touch wood*
    albino1986 Guest
    hey i had the same problem with the whole misfiring thing, it misfired at around 2000-2500 revs in every gear, got to be quiet anooying on the highway, took it to the mechanic and while he was doin the service he also replaced the dizzy cap and rotor, he said they were stuffed, who knows i wasnt gonna ask questions, that fixedthe problem mostly still had some misfiring problems, took it to an autoelec and he replaced my CAS plug, runs like a dream now no misfiring since *touch wood*
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Does it sound like a V8? thats what happened to mine it was running on 5 cylinders minr was a broken lead and that caused an injector to die and my distributer cap had hairline cracks in it.
    ========My Statesman 20's Mafless and 3.9's========
    blackduck11 Guest
    Quote Originally Posted by ryan_VL
    Thanks all.
    Could be the Dwell Angle Sensor playing up also.
    It is located internal of the Distributor. Cost around $150 from Coventry's $200 plus from Auto Electrician.
    Involves complete dismantle of Distributor to replace Sensor.
    Can have this tested by Electrician
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    How old are your spark plugs. They might need changing or the gaps might need resetting they should have a gap of1.0mm if it is wider it can cause surging at low revs.
    VL 5-speed
    Dec 2004
    Hey i took a friends advice and changed my leads, which fixed it. Runs oh so smoothly now and much more responsive. Thanks
    vl lover Guest
    yeah mate its your plug on top off the dizzy, when the car is running give it a wiggle and you will here it miss fire the wires come lose or are corroded nice work.
  1. misfiring?
    By vt_nutta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 06:34 PM
  2. misfiring
    By ciro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 09:02 PM
  3. misfiring?
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2006, 09:20 PM
  4. misfiring..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-07-2006, 11:24 PM
  5. misfiring
    Last Post: 18-06-2006, 11:36 AM
