I have no injecter pulse. What could it be?
Cranks over fine but won't run and I have spark, fuel pump is working, 30lts fuel in the tank, all fuses are new, changed relays all ok.
No Pulse to the injectors! is my computer stuffed?
codes 23,24,31 come up
NEED HELP
try changing crank angle sensor
Yeah crank angle sensor or fuel pressure regulator. Sounds strange tho.
could be a faulty fuel injection relay.
23 Throttle switch circuit (normal)*will disappear when throttle is pressed.
24 Neutral switch circuit (fault in your neutral safety switch)
31 Satisfactory operation (non A/C models)....(A/C circuit fault) A/C models.
no the neutral code will cancel too. just put it from neutral to gear and back to neutral. i'd think the fuel pressure regulator.
good call mate turn out to be a faulty injector relay
Thanks for your help
My friend has the same as you have written above..Originally Posted by minimefx
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
Had a bad connection on the reverse polarity relay on the earth..Originally Posted by mag
Running nice now!!
