well winter has arived finally and so has the eperdemic of condesation forming on the inside of my head lights lens,
how do i stop this?? ive tryd leaving the rear cover off but it still foggs up tryd closing it but i still foggs,
how do i stop it![]()
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
The seal/gasket between the body of the light and the lens is gone...
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
what fekd like broken or might of just diss lodged? is it possible to get new rubbers or is there a alternative to fix this like silicone or gasket goo (got sh*t loads of this stuff laying round)
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
gasket proberly broken, so yeh give the old gasket in a tube a go!!Originally Posted by VL Berlina 5speed
or just go to the wreckers and get some new gaskets (2nd handies) dunno how plentiful vls are in the adelaide wreckers but we got heaps here. I got my strobe lights inside my headlights and had to cut some of the housing to fit them in but I didn't cut the gaskets. I had a hole in the housing that use to make water drops appear in the passenger side light but I plugged it and no more drops.
Ya gotta drop the front bar and remove the moulds to get to the headlight screws (stupid design IMO)
the front bumper bar top trim only needs removing, be careful as it may be brittle and break easily
the light unit will probably be dirty inside with parts of the silver plating missing
be careful of the parking light holder as this is usually hard from the heat and isnt replacable and no one seems to know what to use to replace it
all ya gotta do is take ya grill out and then then unclip the clips at the back of the mould where the grill was and get under the car and there is little black clips that hold the mould in, ya hit them out and then u can remove the mould, and then your headlights
yeah my drivers side headlight was flooded, so got another out a wreck for $20 threw her in, sweet as. Was just a few screws from memory. Remove bumper, undo her throw new one in.
