Results 1 to 4 of 4
Thread: door hold open thing broken
    vl berlina wagon 6cyl
    Jul 2005
    Default door hold open thing broken
    does anyone know how to replace the thing in the drivers door that holds the door open, the arm is still OK
    I looked briefly at this on another VL and it seems difficult to get at, being hard against the window channel, is it riveted in place? or adjustable perhaps?
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    its a prick to get at yes. you prob have to pull off your door trim and get to it from behind there from memory. (i have only ever pulled them out not put them in as i wreck not assemble cars lol) let me know if you need any parts to fix it as i have about 4 drivers doors complete sitting around and i would be happy to pull it out for you etc. i have an ebay store if your interested. my username on ebay is lil_oneblue. or you can email me at j_ackland@aapt.net.au.
    cheers and goodluck
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    are u sure it's the actual arm part cos it matbe the weld vcos that happnendd to my mums car and she had to get ti welded back together lol apparently it's a common thing even on a vt lol
    [SIGPIC][/SIGPIC]
    Surf All Day Guest
    both mine are broken, i think they just always break lol, i replaced my drivers 1 tho $20 for the piece at wreckers, it took half an hour, hardest parts getting trim off,
    Steps
    1) take the backing from the side mirror off, get a screw driver and behind the window winder push off the metal ring This Is IMPORTANT. pull door interia thing out from all the clips then pull directly up then pull off plastic.
    2)i used an alen key with a converter to a bolt size, and undid the origional 1, then pull it out, and put the whole new mechanism in, its a bit of a tight fit and fiddly. then once done put the door interiiior back on and remember to put ring back on with door winder
    more info try personal message me if ya can do that
  1. I think I figured out how to fix this broken thing on JC!
    By VS Omega in forum Site Feedback / Site Problems
    Last Post: 14-01-2007, 02:04 AM
  2. Door will not open.
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 09:36 PM
  3. heater tap broken is this a common thing
    By anotherstockvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-02-2006, 04:50 PM
  4. How To Open Door
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 09:28 PM
  5. back door will not open
    By karter13 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2005, 07:07 PM
