+ Reply to Thread
Results 1 to 14 of 14
Thread: Strong fuel smell from engine bay.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo ucwepn Calais
    WH statesman 5.7
    May 2005
    Default Strong fuel smell from engine bay.
    Hi all driving home last night and on the way home and when I got home I could definately smell fuel and the missus agreed, unsure of what it could be I will check all the lines later with the motor running and see if I can find a leak. I had an injector replaced last week so I'll definately check there and also where my manifold stud is missing is another spot to check. My car is running very rich and using allot of fuel. More than ever before.
    Does anyone else have any experiences that are similar with their vl? are there any common leak spots?
    ========My Statesman 20's + mafless + international ls8 interior========
    bangers's Avatar
    bangers is offline <<<There's a good present bangers has disabled reputation
    EL FALCON XR6
    Aug 2005
    NSW
    does it smell fuely out the exhaust? is the car running rough? if so the injector might be stuck open. if not the fuel line to the engine might be dribbling at the fuel rail from when they replaced the injector. check the line on that particular injector. they might have stripped a thread when puting it all back together and its leaking somewhere. good luck, careful you don't get a fire if it's leaking under bonnet.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    yeah thats what i'm really worried about, a fire. If I can't find the leak i'll take it to ultratune again. It died a couple of days ago (the car) and I limped it to ultratune it started improving on the way and they couldn't find any faults and its been ok since but running roughly and lost power.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Ahhh I found a leaky injector. Its the one they replaced for free (2nd hand) and just charged me for fitting. I'll ring em up and see what the go is. Thanks Bangers.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Yeah they can't do anything until tuesday due to easter so I'm housebound LOL They wanted to replace all the injectors when only one is faulty but I'll set 'em right haha I'm sure ya can get 1 reco injector and not have to buy 6.
    just rang holden and they want $240 for 1 new injector.
    Bax
    Bax is offline Projecting Bax Monaro Bax Monaro
    Nothing
    Jan 2004
    QLD
    Just try ebay. Hell you can get all six reconditioned for less then that.
    I'll sell you 12 or so for 50 bucks, but they're not in flash condition unless you wanted to pick through them.
    Where is it leaking? the Hose? Can the hose clamp be done up tighter?
    Might be a project over easter, rip off the inlet and the fuel rail, get the injectors off, take them in to get cleaned, polish the inlet while its off, then bolt it back up.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Its leaking from the side of the injector itself, under idle its a slight dribble when you rev the motor it drips out the side.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    good to hear you found the problem buddy. generally spare parts places take your injector, send it off and give you an exchange. otherwise it's probably an 'o' ring. take it out and take it to an injector place and see if they can overhaul it. or check the 'o' ring and if it's cracked or brittle see if they'll give you an 'o'ring. don't use any 'o' ring though as they need to be able to take high pressure.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    I think its leaking where the hose meets the injector as they are the type where the hose and injector are an assembly.
    Might see if I can get to the wreckers later and find an ok looking one.
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    240 for an injector Lol.....i have like a 18 of them sitting in my shed lol
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Yeah I laughed at the guy over the phone. I asked for an RB30E injector and he said "what from a gemini?" I'm like huh?
    They come from Asia they are made by uni jecs, Holden must have quite a large markup happening.
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    i have a full set off injectors that where in a running vl i had. i have now stripped the eng and whole car and i haven t sold the injectors as yet. if your on ebay look me up username lil_oneblue or send me an email to j_ackland@aapt.net.au
    cheers and goodluck with it
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Quote Originally Posted by lil_oneblue
    Yeah It can't really wait for ebay as I need it fixed asap. Thanks anyway.
    Apr 2006
    no worries
+ Reply to Thread
  1. Strong Petrol smell in my Vn
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2008, 11:13 AM
  2. 5.0 on LPG with very strong petrol smell
    By VS Callahan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 01:57 PM
  3. Got regased today - strong smell of ? inside car
    By holden_nutt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2006, 12:07 AM
  4. strong fuel odour. help?
    By iwishmyVNwouldstart in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2006, 08:33 PM
  5. Fuel Smell
    By redvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-08-2005, 08:42 PM
