just about every vl ive seen including mine has at one point had rust below the windscreen its those strips above and below the windscreen there watertraps.now ive heard of people using a vt windscreen rubber as a replacement wich is a good idea .has anybody seen or done this, or a similar mod on there vls.cos id like to fix my vls rust problem.
i was talking to a windscreen bloke the other day about this and he said you can put aftermarket rubbers in. there is a hole in the top two corners which need to be filled though before hand.
I did it to mine, it is a universal rubber.
Hi all new member 1st post
Same prob hear rust around window - can someone give me a rough cost on a new seal and window
Mine was bout $180 fitted.
Not sure what mines costing, but its all getting done.
Hey bex, i've seen vn screen rubbers fitted to the vl. Very nice. I was going that way myself until i ended up with the whole car! It gives a lot cleaner appearence but it does leave a slight gap in the top corners. Easy fixed if you are still in primer.
myu dad has had 3 VL;s and he has changed all the rear windown seals with VK seals they fit perfectly and u have no more rust around the windows ive just done the same to my VL BERLINA works like a charm
I didn't think the rears were that bad?
my rear seal is ok, it was my front that was fkd up. i got all the rust cut out lots of money now its resealed again i didnt put the other rubbers on tho.... Meh by the time it sstuffs up again hopefully i wont have my car.
Behind every Great chick, Is a guy checkin' her out
i had the rust on front n back..
jus get a screwdriver out and hack at it, then bog it up. then get some sandpaper n make sure theres no rust left, then get some rust-killa prima, then quick respray.. lookz like new..
jus went qreckers and got some seals, had no problem since..
thank god im getn rid of my vl
I wonder what those scales on the top right side of my posts do...
