Results 1 to 15 of 15
Thread: Accelerator Cable Adjustment
    silvervl Guest
    Default Accelerator Cable Adjustment
    I was doing some little jobbies under the hood this afternoon and i noticed that my accelerator cable was quite slack. So i tried to tighten it via the adjustment nuts but ran out of thread.( why on earth is the thread plastic is beyond me) Anyway i noticed that there was another spot a bit further back but off to the side where said plastic-thread jobbie could sit and make the cable tighter. Is this a Really smart design for when cables stretch, or im i going to have no acceleration when i go to work tomorrow?
    p.s. I have a sharper, more responsive peddle now.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Do you mean the other bracket on the rocker cover? Thats for the cruise control.
    ========My Statesman 20's Mafless and 3.9's========
    silvervl Guest
    executive vt 5.0lt
    Feb 2005
    west suburbs
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Have a look under the dash where the acc pedal is at the top of the pedal there should be like a white stick that gets touched be the pedal when you tramp it and it makes it go slightly harder. If this isn't getting touched you can adjust the stick thingy so it gets touched sooner and it will make it more responsive. If it can't be adjusted I have head of people putting a little bit of garden hose over the stick to make the diameter of the stick bigger so the pedal touches it sooner.
    silvervl Guest
    Thanks bud. I will have a geeze this arvo. I did manage to get a little bit more adjustment out of it this morning.
    How much slack should there be the in the cable?
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    the accelerator cable should be tight enough so it doesnt appear to droop but have enough slack that with one finger you can easily "bend" it.
    you'll know if its too tight, the revs will be too high at idle.
    silvervl Guest
    Thanks heaps. I have put it back to where it is meant to sit and adjusted it accordingly. Resulting in a firmer pedal and a bit more punch off the line. AAAHHH, the simple things.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by ucwepn
    thats your kickdown switch.
    silvervl Guest
    It use to be dowey as through corners kick down wise but now it does as it is told. I am use to old school 'kick down bars' (thanks dad)
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    dumb question but where is the kickdown switch? i looked for mine but couldn't find it.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    its not really a kickdown switch because it wont kick down in certain gears at certain speed when you open the taps right up.
    I might adjust my cable as well.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    don't retighten the nuts too much. i did mine last night and snapped the bloody plastic. superglue works a treat but i had to play with the cable for a while so it didn't get glued inside.
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Quote Originally Posted by bangers
    let me know if you need one i have a good one available.
    cheers
  15. #15
    dobbie Guest
    your about 3 months 2 late i did the same thing
  1. replace accelerator cable
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 02:13 PM
  2. Loose accelerator cable
    By damageinc. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2007, 10:08 PM
  3. Broken Accelerator Cable
    By tristanwalz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 05:19 PM
  4. VR 5.0L accelerator cable / peddle adjustment
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 09:07 PM
  5. Help with accelerator Cable
    Last Post: 13-01-2006, 01:06 PM
