Results 1 to 6 of 6
Thread: supercharger on 6 cyl..
    tougHnA Guest
    Default supercharger on 6 cyl..
    i wanna do this but does any 1 no the comp u need to run for the bottom end??? same as turbo or wat...? i wanna run round 7-10 psi..
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    7-10psi is really pushing one of those little blowers to the limit, I assume you are going with the CRS type of setup using the toyota blower? I think 6 psi is the real power limit for them blowers, after that they run out of puff and can't breathe that hard. with 6 psi you will also need a rising rate fuel regulator and possibly a larger fuel pump and extra injector. with all that you'd prolly gain 35-40% power at the wheels.
    ========My Statesman 20's Mafless and 3.9's========
    VT SS S2 A4
    Aug 2005
    Never driven or been in a supercharged VL, It would be pretty good I think.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    It would definately be torquier than a standard turbo and with the little toggle switch you can turn off the boost at anytime.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    yella terra runs about 8psi.
  1. SC 14 supercharger
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2006, 01:04 AM
  2. V8 or supercharger
    By HVXII in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-09-2006, 11:21 PM
  3. supercharger for vx
    By VX_GIANTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2006, 11:12 PM
  4. Supercharger
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2005, 08:07 AM
