:b: HI, Yes again-Help please ..
I pulled the plug on the AMF and connected the multimeter to pins 1 and 6 and got NO reading!!!
Put the plug back on, roll back the rubber cover pins 1 and 6 again and had a reading of 254 omhs..
Turn the screw reading going up, 300 omhs then back to 0 omhs nothing![]()
Turn screw more still nothing, so turn it back 0 omhs still then back to 300 omhs I can get it lower but WONT go any higher than 300 omhs!!!
Help needed 4 this puzzle. Thanks..![]()
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
was the engine running when u did this? as its not ment to be running!!
and did u have the probes the right way around? think red probe on left socket and black probe on right socket
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Engine was NOT running and NO ignition on.. Probes ok too!!Originally Posted by VL Berlina 5speed
AFM are nothing but trouble!
was it actually showing 0ohms or was it showing OL or something like that like what it shows when the meter is not connected to anything?
If you got OL (or what ever your meter shows for Over Load then set teh ohm range higher)
if 0ohms then maybe u need new afm
VZ Berlina
It shows 0 omhs on 1 and 6 pins with the plug pulled out...Originally Posted by HSVenforcer
do the check with the plug connected to the afm. With plug disconnected it would be open circuit
VZ Berlina
