Results 1 to 3 of 3
Thread: vl - vk loom
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Question vl - vk loom
    will a vl sedan wire loom fit into a vk sedan (diff eng loom)? or are some plugs diff, dash. tail light rear loom to main loom plug, etc?
    cheers
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    not sure but the air boxes on efi vks are on the right hand side where vls are left hand side so there could be a problem with the afm part of the wiring
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    They rarely leave the plugs the same from model to model, simply because everyone would just be "plugging in" the later models bits and gizmo's instead of buying the later model. The dash loom would definately be different ( I had mine out when I swapped to tacho cluster). The VK efi dash loom is different to carby??
    The tailight loom may be the same because the tailights are the same but don't bet on it.
    ========My Statesman 20's Mafless and 3.9's========
  1. VS 5.0L Wiring Loom
    By darwinvest in forum Electrical Wiring / Questions
    Last Post: 25-09-2007, 09:00 PM
  2. Can I replace VN V8 loom with parts of VQ V6 loom?
    By holdenrules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 03:02 AM
  3. wiring loom for vs
    By MR__CALAIS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2007, 10:46 PM
  4. Replace VN Calais loom with VP Calais loom?
    Last Post: 29-12-2006, 05:14 PM
  5. VL Instrument loom
    By Stewart1000 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-11-2005, 05:47 PM
