Results 1 to 2 of 2
Thread: vacuum rubber hoses for heat control
    vl berlina wagon 6cyl
    Jul 2005
    Default vacuum rubber hoses for heat control
    with factory heat and air cond the system uses many vacuum rubber hoses to operate things, the heater water valve is operated by vacuum working some type of motor that adjusts it, its all up under the dash near the steering column
    these vacuum hoses pull off easlly so be careful if feeling around under the dash, the hose had fallen off my water valve control so no heat, fortunately all came good whan I pushed it back on after 20 years, I expect the hoses have lost some elasticity
    the main vacuum tank is under the front bumper bar
    if theres a leak in the vacuum system would this make the engine run lean?
    VL Calais Turbo
    Nov 2005
    i think it would make it run rich cause i had the same thing but for the cruise control and my mechanic said it would run rich
  1. New heater hoses now no heat?
    By fergies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 03:16 AM
  2. Vacuum Hoses... Which Colour Goes Where?!
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 02:37 AM
  3. Vacuum hoses for VS Commodore
    By noizwerx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2006, 10:23 PM
  4. Vacuum hoses on Varijet + 202 Blue Motor, VH Commodore
    By Dr_Mutley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2006, 02:00 PM
  5. Vacuum Hoses
    By Hoffy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2004, 09:45 AM
