Results 1 to 6 of 6
Thread: changing fluids
    vl berlina wagon 6cyl
    Jul 2005
    Default changing fluids
    its said that all additives in lubricants eventually wear out so what about changing the power steering fluid, is this ever done? does it bleed itself, they usually do
    re changing the rear axle oil, does undoing a bottom housing bolt allow the oil to drain out? otherwise I have a syringe
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    not sure bout the pwr steering because if u think bout that then u should do the brakes 2 and if manual the hydrolic clutch,
    with the rear axel i dont think undoing the bolt will work as there is a gasket in there or a sellear, so it wouldnt work best bet is a syringe or hand pump
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by VL Berlina 5speed
    Brakes yes you do, every 12mths change the brake fluid...
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by harry3
    Harry you are correct!!
    Yes you should change both, PWR STEER every 24 mths and DIFF oil 24mths but that depends on how you drive.
    If you tow heavy loads or thrash ur car then you need to change ur diff oil more frequently.
    Also if ur using Synthetic lubricants you can go for longer service intervals..
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    Jun 2005
    South OZ Adelaide
    Unhappy
    Quote Originally Posted by vlv8vic
    i cant believe people dont change the brake fluid!!!
    Yeah you know there only brakes, people would rather brake fade/seized calipars or wheel cylinders/master cylinder..
    Brake fluid soaks up moisture which lowers the boiling point and causes rust, then the seals leak..
  1. changing my name.
    By ULOOK-2 in forum Site Feedback / Site Problems
    Last Post: 31-10-2005, 11:40 PM
  2. Changing to V8
    By Arch_Angel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2005, 10:32 AM
  3. changing k bar
    By murri_rose in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2005, 09:32 AM
  4. changing ecu
    By hakhawk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2005, 07:24 PM
