Results 1 to 5 of 5
Thread: brake master cyl is different in auto and manuals???
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Default brake master cyl is different in auto and manuals???
    i was told they are diff is this correct?
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Apr 2006
    ok so if you was to convert a standard 6cyl auto to manual then master cyl wont need to be changed?
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    You wont need to change the master cyl. Turbo and v8 cyl have a bigger bore and piston to give you a firmer pedal.
    Apr 2006
    yeh i thought that was the case. when the bloke that told me they where dif i thought what the? nah wouldnt be but u told him id check it up.
    cheers
  1. Brake Fluid Master Cylinder
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2006, 07:19 AM
  2. 2 questions - engine q and brake master q
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2006, 07:50 AM
  3. WTB: ASAP!!! brake master - vp v6 qld
    By commy92 in forum Swap / Wanted to Buy / Trade
    Last Post: 11-09-2006, 06:57 AM
  4. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
  5. executive brake master cylinder
    By seventh path in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2004, 07:04 AM
